720 resistor
utupuller
03-04-2008 16:50:36
my 720 LP was not wanting to start. Discovered a resistor that was bad. My question would be, with a 12v system why is there a resistor? I have only seen resistors on 6v systems converted over to 12v.
utupuller
03-05-2008 14:34:31
 Re: thanks/cant wait to use it in reply to utupuller, 03-04-2008 16:50:36
thanks for explaining CLW. I cant wait to pull with it. I have pulled MM for 4 years and the first year I tried my dads JD 70, didnt pull to well. I sold my U last fall and bought a big MM ( GBD ) and sadly sold it. I came across this LP and the price was right. After a few pulls and seeing how it does I may have to change my username lol
Tom 43
03-05-2008 13:29:56
 Re: 720 resistor in reply to utupuller, 03-04-2008 16:50:36
Just because the resistors look the same doesn't mean they are. The resistor off the Chrysler is only about 1/2 ohm as opposed to over 2 ohms from Deere. If you insist on a Chrysler resistor you need a Chrysler point ignition coil to keep amperage within acceptable limits for long point life. All 12 volt automobiles from their introduction in 1955 0r 1956 depending on brand until the advent of electronic ignition in the early 70's used a bypass system for easier starting. However they all had brand specific specifications for the resistance values of the ballast resistors and the coil primary windings. Ford and G.M usually used resistance wires for a ballast. Mixing these coils and resistors is asking for trouble! With too much primary resistance you get weak spark and with too little burned points.
John T
03-05-2008 12:19:34
Puller, A reason why a discrete stand alone external ballast (on a 12 volt system and a 6 volt coil) is used is so it can be by passed (jumped around) as CLW explained. If you had a stand alone (some call internally ballasted) full 12 volt coil its NOT POSSIBLE to apply more then regular voltage durinG the critical start up period while the engine is cranking which reduces battery voltage ESPECIAlLY when its cold.... Buttttt if on a 12 volt system you use a 6 volt coil plus an external stand alone ballast it is indeed possible to by pass around the ballast while cranking (some call start on 12 run on 6) which resuslts in a stronger startign spark to help in cold weather starting.
John T
Mike M
03-05-2008 12:11:51
 Re:too much spare time here's prices. in reply to utupuller, 03-04-2008 16:50:36
Here is a Carquest # RU11 for $5.46 or an RU12 for $6.37 which is a better deal as it is a double unit so you could have a built in spare but it is larger and may take up too much room. These are for the old Chryslers.
Mike M
03-05-2008 12:02:36
For a lower cost subsitute you may try an auto parts store like NAPA. Chrysler used those resistors back in the 60's and 70's ? If you drove one you always carried a spare.Maybe you can find someone who can dig around in the "book" and find one for you that is cheaper.
Duane Larson
03-04-2008 20:43:07
utupuller,
That would be an AA5791R, and it's value is 2.20 ohms, nominally 35 watt resistor. It's still available from Deere for $20.61 around here. CLW explained the reason it's there - part of the "bypass starting" system.
CLW
03-04-2008 18:34:56
 Re: 720 resistor in reply to mlauk, 03-04-2008 16:50:36
I take it you are talking about the one between the switch and coil. On a factory stock 720 LP you have 6V at the coil when the switch is on. When you step on the starter it has a lead from the starter switch that goes to the resistor on the coil side of the resistor that kicks the voltage to the full 12V for starting only. When the starter is released it opens the circuit and 6Vs return to the coil. If the tractor is tuned just right you can "sometimes" get them to start with the starter on just the 6V, but they sure don't like it.
