JD 210C question
screaminghollow
03-03-2008 08:55:44
I recently purchased a backhoe loader with a deisel engine. The rear tire burned up on the left side and burned the entire electrical control panel with it. The seat also burned up, but the engine and transmission were not even scorched. I know I have to be careful about the hoses leaking. For the time being I just want to "jury rig" enough to start it and run it the one mile home. Then I will fix it "right". I have limited knowledge of diesel engines. What wires do I need to run besides a switch & wire to the starter and the fuel flow switch? Does it have glow plugs I need to worry about?
I have ordered a tech manual, but it won't get here for a week yet.
Jonathan in MA
03-03-2008 12:34:51
 Re: JD 210C question in reply to screaminghollow, 03-03-2008 08:55:44
Just the starter and injection pump need power. There are no glow plugs. The "clutch" disconnect is also powered to disconnect, so if that wiring melted together somehow the reverser will not drive. If its disconnected it should drive. But I guess if your just powering up the starter and inj. pump that shouldnt be a problem.
Robert A. Johnson
04-08-2008 05:42:09
 Re: JD 210C question in reply to Jonathan in MA, 03-03-2008 12:34:51
I would get rid of the electronics and install a set of Murphy analog safety guages when rewiring the machine. Never had anything but problems with the logic computer on mine.
