730 D Green Dash
Grabatire
03-01-2008 22:58:07
I recently aquired a 730D Standard and metioned it to a chap I hadn't seen for a while. He asked me if it was a 'green dash' and then went on about how inferior the green dash models were, compared to the black dash, but he admittedly couldn't explain why.
This green dash thing suprises me a bit, considering they all had the same parts in'em, and they all couldn't have been made on a Friday.
CLW
03-02-2008 09:40:08
 Re: 730 D Green Dash in reply to dirtfarmer, 03-01-2008 22:58:07
There is no such thing as a Green and Black dash model in the 30 series. Only the 20 series. The other post are correct as to changes.
buickanddeere
03-01-2008 23:12:22
 Re: 730 D Green Dash in reply to Grabatire, 03-01-2008 22:58:07
You were correct to doubt your buddy. Other than the sheet metal. A blackdash 720 a 730 series are the identical tractor. There are a whack of differences between a 70 and a greendash 720. Transmission speeds, injection pumps, cylinder head etc. There are some updates between a green dash 720 & a blackdash 720.Cylinder head/injector angle/ keystone piston rings/ anti reverse cam. I think anyways, without checking in the parts CD.
RickB
03-02-2008 07:10:53
 Also in reply to buickanddeere, 03-01-2008 23:12:22
At the same time the 720D dash changed from green to black, the electric start option was introduced.
buickanddeere
03-02-2008 14:10:46
 Re: Also in reply to RickB, 03-02-2008 07:10:53
The starting engine was beefed up a bit on the 20 series black dashes. Electric start would be ok in the south but around here. An ES would have to be pulled, belt started or pre-heated from October to March.
wilamayb
03-02-2008 10:08:05
Well sort of.... The "black dash" change occured in July of 1957 but the electric start option was not offered until March of 1958.
If the ES option was available through the whole black dash production we would have "lots" more ES 720 tractors.
