JD 40 SQUEAKY!
BOB GEE
03-01-2008 16:34:30
Maybe someone can help me with this issue. At times, there is a loud squeaking noise coming from the front of the tractor. I"m assuming that it is the fan belt or something associated with it. Sometime when I put a belt squeaking spray compound on the belt, it helps, but it is only a temporary solution. Any suggestions on what the problem may be and a possible permanent solution. Thanks for your time.
johns48jdb
03-02-2008 05:44:53
 Re: JD 40 SQUEAKY! in reply to BOB GEE, 03-01-2008 16:34:30
replace the fan belt first. yours sounds like its just dried out.
RobMD
03-01-2008 19:34:30
It can also be the generator! some of these units have not been drip-oiled in years and years.
BUTCH GA.
03-01-2008 16:51:23
BOB if you have the old style fan the bearing needs oil in it. look real close in there and you will see the little cap to open and put oil in it. If you have the new style the bearing is going bad.
