35 b rear steel
rytre
03-01-2008 11:06:35
Could you please give me information on what the original steel wheel size was on a 1935 john deere b. Part number of these rear rims. How many bars how many inch rim etc. thanks
fixerupper
03-01-2008 12:01:42
 Re: 35 b rear steel in reply to rytre, 03-01-2008 11:06:35
The parts book I have shows a 48" rim pn.JD1265R.
Spade lugs were either 4" or 5" tall and came in packages of eight. This is for the flat rim. It doesn't list a size for the skeleton rim. Someone else probably has more information. Jim
fixerupper
03-01-2008 12:09:16
 Re: 35 b rear steel in reply to fixerupper, 03-01-2008 12:01:42
Part # for the skeleton is JD 1266R.
Duane Larson
03-01-2008 11:59:27
rtyre,
Are you needing information for flat steel rear wheels or skeleton rear wheels?
rytre
03-01-2008 12:01:56
 Re: 35 b rear steel in reply to Duane Larson, 03-01-2008 11:59:27
skeleton rear steel please
Duane Larson
03-01-2008 12:52:52
 Re: 35 b rear steel in reply to rytre, 03-01-2008 12:01:56
rtyre,
Assuming your '35B has a s/n between 1000-12011, the skeleton wheels were furnished by French & Hecht, casting number HC177, JD p/n AB363. The wheels had 10-1 1/2" x 7/16" spokes, and the wheel was 48" in diameter with a 1 15/16" outer "rim". Twenty cast lugs B496R were used per wheel, with A685 spacers.
After 12012, JD skeleton wheels were used, same size, no casting number but p/n JD1224. The cast lugs were unevenly spaced on those wheels.
Deere and Webber, the Minneapolis Branch House, did not offer B's on skeleton wheels in their 1935-36 price lists as the soil in their territory took too much of the tractor's hp just to move the tractor on skeletons.
