70D Crankcase Smokin???
Gary U in NJ
11-02-2003 14:14:42
Hey everyone:
I was just doing some light mowing today and encountered the following problem:
1 The engine began to run a bit rough
2 It started running a bit richer (black exhaust but not much)
3 I noticed smoke coming out of the crackcase ventilation tube to the pony motor
4 A definate loss in power
So far I checked: Intake, which is clear.
Fuel which is clear.
Oil quantity which was ok, and I brought it to full.
Temperature and oil pressure is great.
No sign of excessive heat anywhere.
I have restarted it several times, seems a bit fussy which it has never been, and it is generating more black smoke than usual.
My main concern is the smoking of the crankcase. The odor is not Diesel, its not coolent more like oil.
Whats you thoughts???
Gary
Clooney
11-02-2003 16:52:21
 Re: 70D Crankcase Smokin??? in reply to Gary U in NJ, 11-02-2003 14:14:42
Gary, you didn't furnish us enough information to do more that just take a guess at your problem.
~You could have anything from a plugged or malfunctioning fuel injector, to a broken piston or broken/stuck rings, to a leaking fuel injector line, to a sticking valve, to a cracked pony heat exchanger, to ?
~Probably the place to start is during pony running,,, see if you are getting any pony exhaust smoke out of the diesel air intake [if so suspect a leaking pony heat exchanger in the diesel intake]. That will allow some pony vent smoking but should clear up after a short use so is doubtful that's your problem.
~Then sniff the engine oil for signs of diesel oil smell [if the oil smells like diesel fuel suspect a cracked or leaking injector line]..
~Next you might want to pull both fuel injectors, then turn them around so the spray nozzles are pointing forward, then crank the engine with the fuel lever turned up & see if the spray patterns are even, the same between them, a nice fine mist. & about the same amount [don't worry about trying to hook up the by-pass lines, just leave them open & pointing down] ... CAUTION: don't put your hand in front of the spray nozzles as those high pressure injectors can inject the fuel right through your skin... If you have a mis-firing injector it will allow loose rings to not seal during poor firing & that can lead to blow-by.
~Next you should try to make an air fitting from an old injector & try to run a compression test, then also put about 100+ lbs of air pressure in each cylinder [with the valves closed] & run a leakdown test to see if you have excess ring blow-by.
~Your problem could be something quite simple like a fuel injector problem, or complicated like a broken piston or piston pin that came lose & tore up a cylinder wall, to almost anything in between..
~Do the simple things first to eliminate those then you will have to decide how far you will [or are willing] to go..
~Post back with questions & findings..
[email protected]
Gary U in NJ
11-03-2003 02:56:57
 Re: Re: 70D Crankcase Smokin??? in reply to Clooney , 11-02-2003 16:52:21
Clooney:
Good to hear from you!
I just responded to Frank with some details, and I apreciate you recomendations. The big question is the smoke. I believe it smells like oil (hot oil). I allowed the tractor to cool (even though it was not hot to begin with) and restarted it. The oil smoke out the breather began within a minute. The pony and its plumbing is all fine, I believe the problem lies more toward the main engine (remember its only my feeling).
I mentioned to Frank that I may be traveling beginnning on Monday which means I'll have to pick this up next weekend. If you don't mind kick it around, I appreciate your help.
Gary
F-I-T
11-02-2003 16:49:04
Gary:
If it came on suddenly, I'd say you might have a piece of grit in an injector or a fouled nozzle tip. The fumes out of the breather are a stumper to me, because that really can only be from a blow-by situation. However, an injector hanging up even partially will make them run rough, smoke from faint to a lot, etc.
Make sure the fuel flow through the filters is good.
Why not do the cheap stuff first. Take the oil bath aircleaner cup off and run it to see if a clob of dirt broke loose. Then take off the valve cover and crack each injector nut, one at a time to see if one doesn't change the engine speed or sound like it should if it were disabled. Then, you could check the timing while you're there. I would also check that the decompression lever is released completely. You can check that by disconnecting the yoke. If it springs forward, it might be too tight.
You could have a valve tappet that backed away, and the exhaust is not exiting correctly, and possibly letting those gases go up a valve guide and into the crankcase for venting. Also, when you crack each injector, look and see if the fuming stops at the pony vent.
That's all I can think of for now. Wish you luck!
Frank
Gary U in NJ
11-03-2003 02:48:07
 Re: Re: 70D Crankcase Smokin??? in reply to F-I-T, 11-02-2003 16:49:04
Hi Frank:
Appreciate the feedback - yes it did come suddenly. I noticed it beginning to run rough and then saw smoke around the pony. About then I shut it down in fear I had something about to catch fire. The smoke out the breather is not slight, its definatly pushing a good bit every cycle - and the smell is like oil.
As usual, its always something on a Sunday just before I have to leave town for the week! BTW I did get the PTO clutch overhauled, all new parts and runs great - many thanks!
Gary
Aaron
11-02-2003 14:46:17
Gary about the only thing i can think of for the crankcase smoke would be blow by from the rings. What color is the smoke coming out of there. Is there any signs of slobber at the muffler? If not maybe you have an injecter problem. Sorry i couldnt help more.
Aaron
Gary U in NJ
11-02-2003 16:19:41
 Re: Re: 70D Crankcase Smokin??? in reply to Aaron, 11-02-2003 14:46:17
Thanks for the reply:
My feeling is that it is oil smoke out of the breather pipe, thats what it smells like. Its not faint, its a good bit within a minute or so after starting. I was thinking the same (blow by) but whatever it is it has definatly affected how the engine is running.
