2350 gaining oil
mjbrown
02-29-2008 12:20:31
My 2350 seems to gain oil in the crankcase. It isn't coolant and it doesn't smell like diesel. The tranny/hydraulic fluid seems to go down an equal amount. Is the hydraulic pump mounted on the engine where a bad seal would let fluid into the engine?
backwoodsfarm
03-01-2008 06:02:17
 Re: 2350 gaining oil in reply to mjbrown, 02-29-2008 12:20:31
MOST of the time, that problem is caused by fuel leaking into the crankcase via the fuel transfer pump. They are fairly cheap to buy or rebuild and easy to change. I would try that first, change the oil and see what happens. I have had that same thing happen on my 2555 and 1530.
Tx Jim
03-01-2008 04:30:00
 Re: 2350 gaining oil in reply to dogger, 02-29-2008 12:20:31
The 2350 has no hyd pump mounted on engine. The hyd oil cooler is attached to radiator but with no liquids interaction. I'll vote for fuel contamination of engine oil. Jim
mjbrown
03-01-2008 08:18:25
 Re: 2350 gaining oil in reply to Tx Jim, 03-01-2008 04:30:00
Thanks for the replies.
