3010 with hyd drive hay rake
poortdirtfarmer
02-29-2008 03:32:46
O.K. I HAVE A 3010 , JUST BOUGHT A NEW HOLLAND HYD DRIVE SIDE DELIVERY RAKE, DO I JUST HOOK THE TWO HOSES TO THE OUTLET AND PUSH THE HYD LEVER FORWARD TO OPERATE, OR DO I NEED TO HAVE A LINE FREE FLOWING BACK TO THE SUMP OR REAR END. THANK FOR ANY HELP.
Gerald J.
02-29-2008 09:17:29
 Re: 3010 with hyd drive hay rake in reply to poortdirtfarmer, 02-29-2008 03:32:46
I think it should work just fine that way. You might find the valve setting touchy, and in that case a flow restriction valve or orifice in the supply line might be handy.
Be careful about stopping the hydraulic motor. It would be best to go to the float position rather than the cylinder hold position because cylinder hold will STOP that motor instantly and the rake parts may want to run on, breaking stuff.
Gerald J.
Jake Winn
02-29-2008 07:08:08
What might work best is to put a ported hyd filter cover on it. This puts a fitting on the cover and sends the return oil from the rake to the charge circut for the hydraulic pump. You can put a Pioneer end on the cover and run a jumper hose from the cover to the back of the machine.
