8970 jd
wg
02-28-2008 20:52:54
I have purchased an 8970 it has 710 x38 duals 6100Hrs should I be aware of any issues with these tractors also would like to hear what you think about this model.
Mike w J
02-29-2008 15:19:08
 Re: 8970 jd in reply to wg, 02-28-2008 20:52:54
I got an 8770 and an 8960. The 8960 is just about the same tractor as the 8970 . The only problem we have ever had is hydralic lines on the 8960 . They made alot of improvement on the routeing and clamping of the hoses. You will really like the cummins motor . it can be lugged down all day at 1700 rmp and not hurt it. When it starts to power hop pull the throttle back to 1000 and it will quit hopping push the throttle back ahead and it will take off . That tractor is better on fuel then the 8770 . We have 6500 hours on the 8960 and about 3500 on the 8770 .
wg
02-29-2008 17:52:24
 Re: 8970 jd in reply to Mike w J, 02-29-2008 15:19:08
Thanks
I have the tractor at home now the only thing that concerns me is that the steering is very sensitive when 20 Mph range. I have not had any slow speed experiance with this tractor sso I don't know how it will be. Have you had any issues with a similar problem?
Mike w J
02-29-2008 18:40:28
 Re: 8970 jd in reply to wg, 02-29-2008 17:52:24
check for worn bushings on steering cylinders if steering gets jerky . They do steer fast but when jerky it is most likely bushing .
