1927 D valve guides
LN
02-28-2008 17:44:10
I am working on a cylinder head off of a 1927 D
need to install new valve guides ,the old ones have already been removed( by someone else) I need to know which way to point the oil hole in the guide . was told by one person to install them with the oil pointing towards the manifold side so oil would drip into it, was told by someone else that it has to be pointed down for the oil to be able to get out, am confused and do not know what to do ,any help or opinions greatly appreciated
Mike M
03-03-2008 12:27:50
 Re: 1927 D valve guides in reply to LN, 02-28-2008 17:44:10
No one else chimed in yet so ? You may want to try reposting this to get some fresh viewers ? I had one of those tractors years back but can't say for sure how those holes go. My first instincts say to the top ? so oil can get in. I'd check the valve cover to see if there is a trough with holes that may indicate that it does drip oil down onto the valves and try to see how far out it drips and if it will match up to the guide holes. I can't say for sure which way they go ,but try doing some measuring and see if it shows any clues.
