CRUD
FATAL
02-28-2008 13:24:55
Replacing core in the old G is there any way to clean crud out of top and bottom tanks.thanks
Lee B
02-29-2008 00:50:19
 Re: CRUD in reply to FATAL, 02-28-2008 13:24:55
One cheap and corrosive way is to use Muratic acid on warmed up parts. That will create dangerous hydrogen fumes that can gag a maggot at 50 feet guaranteed if the wind or lack of it is just right.
But done carefully with the above knowledge firmly adhered to, I know of no easier, faster method to eat up a bunch of nasty crudy rust. Warm parts is the key here, but never hot. Use lots of water to rinse it away and dilute it when done.
Muratic acid is readily available from most hardware stores, it is used to etch the alkaline mortar from brick work when wrapping up a job as a finalizing step. It takes all the smears and minor bits of mortar and eats it up. It is actually 30% Hydrochloric acid.
Dave H
02-28-2008 18:51:44
You could also google (cleaning parts with electrolysis)
PBrowning
02-28-2008 14:45:17
Sand blasting also works since you have it apart. Gosh -- there must be a gazillion ways. (PatB)
old popper
02-28-2008 14:01:30
I don't know what kind of crud you have, but if it is rust and mineral deposits, you could try a "needle scaler". Or there are products to chemically remove this type of "lime" deposits. I don't know where you would purchase any but my employer uses a product called "Rydlime" or something like that. Non-corrosive, won't hurt your skin, and does a really good job. Good luck with the "G". Dale
