720 on LP doesn't start HELP!!!!
Kevin Laseter
02-27-2008 18:34:56
A while back I was using my 720, parked it in the evening, and the next morning I got on it only to find it would crank but not start. I had plenty of lp, good cranking speed but no spark. Recently I replaced plugs, cap, rotor, points, condensor, plug wires, and coil mainly because the parts were probably as old as I am. I now have spark, but it still will not fire up. Here are a few stats: good battery, good battery cables, new everything on ignition as mentioned before (points and plugs properly gapped), 65% full on lp tank, 12 VDC switched ignition @ fuel solenoid, no pin holes or cracks in either of the two diaphrams in regulator, correct level and type of oil in air cleaner, voltage on fuel solenoid stays while cranking, and coolant is topped off(in regards to regulator). Regulator is a century model "H" so it has a purge/prime button on the back side. If I depress this button it tries to start, but never will fire up. Valve lash is set and compression is good. Have I overlooked something ,or do I need admit myself to the local looney ward?
TEXASJ
02-28-2008 11:42:28
 Re: 720 on LP doesn't start HELP!!!! in reply to Kevin Laseter, 02-27-2008 18:34:56
Did you get a 12v cap or 6v?
Kevin Laseter
02-28-2008 16:06:05
 Re: 720 on LP doesn't start HELP!!!! in reply to TEXASJ, 02-28-2008 11:42:28
12 volt cap came in kit from yesterday's tractor. Although I've not verified that the kit was supposed to be for a 12 volt system.
CLW
02-27-2008 19:22:36
 Re: 720 on LP doesn't start HELP!!!! in reply to jdhbag, 02-27-2008 18:34:56
Kevin, are you getting the full 12V to the coil when the starter is pressed. Bad igniton resistor, or open lead not allowing but 6V maybe. Could try a jumper wire from - side of Batt. to - side of coil while cranking to check circuit.
Kevin Laseter
02-28-2008 16:03:11
 Re: 720 on LP doesn't start HELP!!!! in reply to CLW, 02-27-2008 19:22:36
Yes it is getting full voltage however I did try the jumper wire just to put my mind at ease.
J. D. from the south
02-27-2008 18:58:19
When you say fuel solenoid are you referring to the electric shut-off and strainer located in the fuel line between the tank and regulator? If not, check to make sure it is opening for good fuel flow. I had a 730 do the same thing and the coil had burned out in the shut-off valve above the strainer.
Kevin Laseter
02-28-2008 15:59:56
 Re: 720 on LP doesn't start HELP!!!! in reply to J. D. from the south, 02-27-2008 18:58:19
Yes and I do know that it is allowing fuel past upon turning on ign.
