JD 730 Starter and Gen. Grounding
Joe Hartman
02-27-2008 17:45:42
Have our starter and Gen at a shop getting checked over while the engine is down. The 720 SM dosn"t talk about the starter. Just want to make sure I tell them correctly. The Generator is a 6 volt neg. ground, and starter 24 volt neg. ground right? Thanks Joe
John T
02-27-2008 20:10:32
 Re: JD 730 Starter and Gen. Grounding in reply to Joe Hartman, 02-27-2008 17:45:42
If a Pony its wired at Pos ground and has a 6 volt starter and generator n battery, of course. If its an electric start its a 24 volt 2 wire NON grounded genny and a 24 volt 2 wire NON grounded starter motor and has two 12 volt (or four 6 volt) batteries wired in series to get the 24 volts.
John T
Joe Hartman
03-01-2008 13:22:31
 Re: JD 730 Starter and Gen. Grounding in reply to John T, 02-27-2008 20:10:32
Ok so is it NON grounded or positive ground? Where is the electrical system for the 730 published? Thanks Joe
Tom 43
02-27-2008 19:41:20
If you have an electric start diesel tractor it is positive ground as are all two-cylinder John Deere tractors. Starting and charging is 24 volt. The only "split" part are the lights, fuel gauge, and rear implement outlet. Even the generator light is on a 24 volt circuit with a resistor in the circuit to protect the 12 volt bulb from 24 volts.
long green line man
02-27-2008 19:00:42
If your 720 is electic start it will have 24v.starter & 24v. gen. (what they call split 12v.) If it's pony motor start it's all 6v.
