70 manual steering
Curtis70
02-27-2008 15:35:20
I have put the steering assembly back together, trying to remove excess free travel of the steering wheel. I made adjustments with shims with the front wheels clear of the ground. Tractor has tricycle front. I have .015 in shims between worm housing and the pedestal, and about 3/16 inch of gasket material between the bearing housing and the worm housing. Anything less either place, the steering binds. The wheels turn the same amount in both directions. Do I have something wrong? I am afraid I will break something. Thanks for your help.
Mike M
02-28-2008 04:24:17
 Re: 70 manual steering in reply to Curtis70, 02-27-2008 15:35:20
how's the up and down play of the spindle shaft ? And have you tried to turn the sector gear 180* to a possibly unworn spot ?
Curtis70
02-28-2008 07:56:28
 Re: 70 manual steering in reply to Mike M, 02-28-2008 04:24:17
Mike, thanks, no I have not checked the up and down play of the shaft or turned the shaft 180 degrees. Will check into both. Thanks again. Curtis
