JD 2010 D with 36A loader
Phil in MS
11-02-2003 14:06:08
Local John Deere dealer has a row crop JD 2010 diesel with a JD 36A loader. Serial number R44325 makes it a 1964 model. Tractor and loader are weathered but sheet metal looks Ok. It does need the two side panels over the radiator. Has almost new 12.4 X 36 rear tires and the fronts are 9.5LX15 implement tires that are dry rotted and should be replaced. The frontend on the tractor is banged up and there is some fluid leakage in the area. Loader is dry and doesn't appear to be banged up for its age. Have no idea of the price but would consider tractor to use to feed hay. Has a long flat steel lever on the left side of seat that looks like it could be a hand brake or PTO lever. Also has tall round lever on right side of seat. Anyone know what these are? Has two levers on the dash to the left of the steering wheel.
Would a used front end be hard and expensive to come by? I would likely get a new steering wheel and a new seat or seat cushions. Has flat top fenders with brackets for two headlights on both sides which are out.
Any comments welcome. By the way I have a 1975 MF 255 diesel as my current tractor that I have been planning to spend from 2,000 to 3,000 for a used loader. If this 2010 is priced near 3,000 I might consider it.
Thanks
firedog
11-03-2003 10:04:14
 Re: JD 2010 D with 36A loader in reply to Phil in MS, 11-02-2003 14:06:08
Do yourself a favor and get a loader for your massey. You will have down pressure and no problems from the hydraulic system. The hyd systems on the JD 2010 are notorius for being almost unrepairable today.
You could probabaly buy a new loader from some of the after market companies for what that dealer will want for the JD.
Good Luck to you
firedog
Mark Scholten
11-02-2003 17:40:46
It was quite a few years ago but if my fading memory serves me right, the lever on the left of the seat is to engage the PTO. Forward on, back off. I don't recall any lever on the right of the seat but around midnight tomorrow night i will remember that. The 2 levers on the left side of the dash are for raising the 3 point and a remote cylinder.(one lever for each).
I am sure someone else will post and if I am wrong, correct me. I don't think you will get a tractor like this for the range your talking. I just saw a 3010 D go for $6500.00 with no attachments here in Michigan.
Good luck. Mark in Michigan
