JD 4020 pto
sfrms
02-27-2008 13:18:34
Can the pto on my 4020 powershift tractor be repaired without splitting the tractor?
WTW
02-27-2008 14:02:50
 Re: JD 4020 pto in reply to sfrms, 02-27-2008 13:18:34
All depends what is wrong with it. If your problem is valve related tractor does not have to be split. If your problem is PTO clutch tractor will have to be split at engine/clutch housing. If your problem is PTO brake shoe related tractor will have to be split at engine/clutch housing and then again between clutch housing and transmission. Better get some gauges to determine where your problems are before you proceed on a witch hunt. Good Luck, DW
