Injector pump question
jd2140
02-26-2008 20:29:05
I was letting my JD 2140 warm up this afternoon and noticed fuel coming from the injector pump, it was spraying out around the timing hole cover, so i shut the tractor off and got a 5/16" nut driver and tightened the cap screws up, and the leak stopped, anybody ever had this problem before? I hoped that fixed it but who knows, i was wondering one thing, it had wire going through both cap screws and had a lead looking piece of metal in the center of the wire, whats that for? some of the wire had been broke, if it was to keep the screws from backing out that might be why they did.
Texasmark
02-27-2008 05:47:49
 Re: Injector pump question in reply to jd2140, 02-26-2008 20:29:05
10-4 on the security part of it (and locking). If you turn up your pump (for more hp) it voids the warranty. People do it and OEM's apparently got tired of having to replace them in warranty when it was the user's fault for the failure. The lead seal usually has a logo on it for determining who put it on.
Mark
shrike
02-27-2008 03:01:22
Your correct. The wire is twisted in such a way as to prevent the bolts from backing out, and are also to seal the pump so anyone can see the pumps been tampered with. Be careful tighening these bolts as there is a specific tourque for them and they're in aluminum and will strip easly.
jd2140
02-27-2008 07:40:14
 Re: Injector pump question in reply to shrike, 02-27-2008 03:01:22
well i had to tighten them pretty tight to get it to stop leaking, is there any reason it would just start to leak? i used the tractor on sunday and it was fine, which the bolts were a little lose.
