730 vs. 720 pony motor
tractorpuller00
02-26-2008 18:46:48
Is the pony motor on a 730 Diesel the same (in parts) as a pony on a 720 Diesel?
wilamayb
02-26-2008 19:27:10
 Re: 730 vs. 720 pony motor in reply to tractorpuller00, 02-26-2008 18:46:48
There are several differences according to the parts catalog including Crankshaft and cylinder heads if the 720 is before SN 7214899, as well as the carburetor parts that Duane listed.
That is certainly not to say that they wont interchange if you use the correct thrust washers and main seals. I'm not exactly what the differences are with the cylinder heads. Maybe there is a pony expert that can answer that.
Duane Larson
02-26-2008 19:05:08
After 720 s/n 7214900, and for all 730 the starting engine used a AF3775R Zenith O-12172 carburetor. It has several different parts (venturi size, main jet, throttle shaft, and compensating jet) than the AF2146R used on earlier 720's. The change was made when Deere started providing serial numbers for the starting engines (SE1000-).
GeorgiaHayFarmer
02-27-2008 04:29:41
 Re: 730 vs. 720 pony motor in reply to Duane Larson, 02-26-2008 19:05:08
Duane Larson,
Do you or anyone else know if the new and used carb parts are easier to come by for the later model carbs? Or are they about the same. Are they interchangeable from late model to early model starter engines? I work a late 720D.
Scott
Duane Larson
02-27-2008 17:16:31
 Re: 730 vs. 720 pony motor in reply to GeorgiaHayFarmer, 02-27-2008 04:29:41
The later carb was apparently substituted for the earlier one. I don't know about relative costs for parts.
