410 D backhoe.
Buck eye al
02-26-2008 15:42:01
Friend has a 410 Backhoe with a diesel engine. Runs fine but is a hard start. Decided to check the pump timing. Rolled it 'round & inserted the timing pin, opened the window. Rats. Must be at #4. Closed it back (to stop fuel loss) then pulled the pin & rolled it over (with screwdriver) one turn & put he pin back in to check on this cylinder. Opened the timing window & no marks.
Hmmmm.
Kept the window open & started to roll it (with the screwdriver) again. Went one whole crank revolution & still no marks.
Kept on going several ring gear teeth past TDC and finally here came the timing mark into the window.
Seeing this, we rotated the pump to align the marks as specified but ran out of slot in the pump base plate before we got the marks into line. We're still about .1" from being in line in the pump window late.
Starts a good bit better but we suspect getting them into line likely to make still greater improvement.
Question is.... what is most likely to be the source of this timing problem? An internal pump problem or a timing gear train assembly or wear problem. We've never been in to the timing gear train so can't speak to a drive train assembly error. Would think if it was just wear it would make quite a racket but this engine is not noisy.
Have seen the reactions of "the disintegrating ring" of the Roosa Pumps on the 4020, an 806, a 1955 Oliver (Waukesha enine) and a 3020. Have not seen any of that behavior here on the hoe. Once he's started, he behaves well.
I'm leaning towards it being a gear train assembly error by somebody in the past but would like a second opinion or guidance from someone that might already have been there & done that! Lots of digging to get there only to find nothing wrong!
Opinions/suggestions?
twopop
02-26-2008 19:19:22
 Re: 410 D backhoe. in reply to Buck eye al, 02-26-2008 15:42:01
I dont know what engine you have,but on a 3020 or 4020 it is possible to put it out of time if the oil pump is not installed properly.on these tractors the pump slot in the oil pump sits at about 15 degrees up from paralell to the engine.if you have a manual for the motor,check out the oil pump installation
buck eye al
02-27-2008 08:20:53
 Re: 410 D backhoe. in reply to twopop, 02-26-2008 19:19:22
Understand and I say thanks for the reply.
This engine's is not like the 3020. This injector pump shaft runs parallel to the crank shaft, is on the left side of the engine right behind where the ventilator pump is on a 4020.
Have read the JD shop manual over and over and can see nothing other than improper assembly or SERIOUS injector pump troubles that could cause this problem. If there's anything in that manual describing this problem in a trouble shooting manner I'll be a monkey's uncle if I know what section or group it's in! Not even anything like on the 2 cylinders where when the crank is #1 TDC, the mag drive coupling slot should be horizontal, if it isn't the gear train is out of time.
Appreciate your time on this and thanks again.
Jonathan in MA
02-27-2008 09:35:31
 Re: 410 D backhoe. in reply to buck eye al, 02-27-2008 08:20:53
My guess would be an assembly error by someone in a past repair. With the pump removed that drive gear can move around quite a bit.maybe even can get it to jump a tooth. I"m assuming you have an old 410 with a D in the serial number, but not an actual 410D built in the mid 90"s ? I never actually tried it, but it may be possible with a little effort to get the pump shaft and gear to skip a tooth with just the pump removed from the engine... Maybe worth a try to see if that will get the pump back into "adjustable" range of the bolt slots.Be careful reinstalling the pump on the shaft seals.
buck eye al
02-27-2008 15:21:06
 Re: 410 D backhoe. in reply to Jonathan in MA, 02-27-2008 09:35:31
A 410D NOT of the 90's! He'd already been retired once by the time the 90's rolled 'round & came to live here. I appreciate your suggestion. Like I said, haven't been in there & don't know what "tricks" the book doesn't suggest might be available. Will be gald to try that as opposed to peeling off eveything north of the block!
We'll wait for a bit warmer weather (no heat in his shop) & get to it in a few weeks. Will post back with whatever we ultimately do and find.
Thanks again.
