4 bolt B
Iowajohn
02-26-2008 11:14:17
Thank you for answering my past questions,I"ve always gotten great advice here. I"m looking at an early unstyled "B" it only has 4 bolts holding the front to the side frames. It does not have the bolts next to the pedestal. Am I looking at a 4 bolt "B"? As Always Thank you
IowaJohn
02-26-2008 19:46:44
 Re: 4 bolt B in reply to Iowajohn, 02-26-2008 11:14:17
Thank You all again you are so much help, Hey I'm looking at a put together tractor, it has the 4 bolt front end but the serial number is in the 9 thousands.
BMAN
02-27-2008 05:42:46
 Re: 4 bolt B in reply to IowaJohn, 02-26-2008 19:46:44
If the serial number is above 3042 it would not be a true 4 bolt B. I have a lead on a 4 bolt B that needs a 4 bolt pedestal. Email me and maybe we can put together a true 4 bolt B. I'm in Iowa also.
B from Texas
02-26-2008 14:33:10
Mike M,
What is the "needed" range. Who wouldn't need a 4 bolt B?
Mike M
02-27-2008 05:24:57
 Re: 4 bolt B in reply to B from Texas, 02-26-2008 14:33:10
I think others have come up with that # range.
And as far as "needing" one ? In this day and age of high prices and fake tractors nobody needs taken ! So they NEED to be VERY careful when buying if in a high price range. An unstyled B is an unstyled B to me ? so I'll just be happy with my much cheaper priced '36 version.
RobMD
02-26-2008 18:08:16
if you have a serial number thats out of range for 4 bolt B's, then you have a put together tractor.
RobMD
02-26-2008 12:25:51
Remember to check that serial #. A 4 bolt is useless without a tag. (They could put a 4 bolt pedestal on a 38 tractor, for example).
IowaJohn
02-26-2008 12:35:35
 Re: 4 bolt B in reply to RobMD, 02-26-2008 12:25:51
What serial number am I looking for? Thank You
WTW
02-26-2008 13:08:22
 Re: 4 bolt B in reply to IowaJohn, 02-26-2008 12:35:35
Serial Numbers for the 4-bolt tractors are 1000-3042. That would make the first 2042 tractors 4-bolt models. Along with the 4-bolt front pedestal the frame is also unique to these tractors. The frame is short and is fabricated from angle iron, unlike the cast frame that replaced it starting at 3043 serial number tractors. There is other small differences as well including fuel shut off valve as used on early model A tractors, flywheel casting numbers and top crankcase cover casting numbers. My 4-bolt is serial number 303? One of the last ones made. Mine is also an Iowa tractor. Don't let it get away if you want one! DW
THE SMOOTHED DEERES
02-26-2008 18:45:41
 Re: 4 bolt B in reply to WTW, 02-26-2008 13:08:22
You lucky dog ! Is the front weak looking ,does it look like it could be prone to breakage having only four bolts up there ?
WTW
02-27-2008 10:18:34
 Re: 4 bolt B in reply to THE SMOOTHED DEERES, 02-26-2008 18:45:41
Front pedestal on my 4-bolt B looks fine and shows no stress or cracks. It looks like an unstyled model A front pedestal only smaller. Unstyled A tractors had just the four bolts that you could see but there is actually five. The fifth is under the frame on the back side of pedestal on the A. The 4-bolt B did not have this hidden fifth bolt. That may had been the reason they were made into the heavier 8 bolt front ends. I do / did feel very lucky to find and buy this late model 4-bolt tractor in original running condition (still can read words Model B on small gas tank). I felt much more blessed the following year when I found my 1938 BI setting in a farmers shed. Both tractors were bought local in the Eastern Iowa area. I was told by the (now deceased) farmer I bought the 1935 4-bolt B from, that I am the third owner of it. He had bought it when it was only a few years old. I found it in 1990. DW
RobMD
02-26-2008 19:29:46
That's why they went to the 8 bolt and cast front.
old
02-26-2008 12:59:17
The serial number will be real low. I can't tell you how low but I can say it would be a lot lower then what my B is and its 9405 brass tag 1935 B and its the 8 bolt type
Mike M
02-26-2008 11:59:32
Your also going to have to check the serial number to see if it falls within the "needed" range.
