All Fuel 3-way fuel valve question
Nathan Kapp
02-26-2008 10:42:31
Hi all, Ive got this 1951 all fuel here and I am looking for a 3-way valve. Did Deere use the same valve over the years? For example, would a mid 1940s valve be the same as on my 1951? I know the early deeres were a little different, but would like to get the right one for this tractor. Thanks.
Nate
Nathan Kapp
02-26-2008 17:08:05
 Re: All Fuel 3-way fuel valve question in reply to Nathan Kapp, 02-26-2008 10:42:31
Okay, I checked my parts book out and found that it is AB2805R. I found a nice valve that is very clean. The guy doesn't know part # but knows it came off a 1941 B. So, my question is would a 41 B have the same part number listed? Thanks again for all your knowledge!!!
Nate
PBrowning
02-26-2008 17:39:07
 Re: All Fuel 3-way fuel valve question in reply to Nathan Kapp, 02-26-2008 17:08:05
PC330 calls out AN2805R for all-fuel "B" tractors, 94494 through 305246. Yes, if you have a 1941 "B" donor tractor, the part should be the same.
The AB2805R will have a full-round stem coming from the valve whereas with AB1545R valves from earlier "B" tractors, we see the valve shaft coming out full round, and then machined to "half-round" where it met with the indexing stop that adapts control to valve. When the valve changed, obviously also changed was the indexing stop. (PatB)
Nathan Kapp
02-26-2008 17:54:41
 Re: All Fuel 3-way fuel valve question in reply to PBrowning, 02-26-2008 17:39:07
PatB, Thanks again for your wealth of knowledge. Take care!
Nate
RobMD
02-26-2008 12:24:19
I bought the very last new one made from Deere for my 520 about 6 years ago.
Mike M
02-26-2008 12:06:32
There is a really good chance any of them that have a control rod hooked to them to run through the dash are the same as you need. Like Pat said the exact answer lies in those parts books.
PBrowning
02-26-2008 11:01:32
Nathan -- The 3-way valve came under two or three different part numbers over the years. Pull out your parts catalog (fuel systems section) and in accord with the serial number for your tractor, the right one should be called out. (PatB)
