720 GAS
EARL IN INDIANA
02-26-2008 04:16:20
The 720 gas that I am working on bringing back to life has only 1 wire running to the generator. That wire is the battery wire from the voltage regualtor to the amp guage. Now I know that there is usally a second wire. I know the second wire hooks to the center terminal on the voltage regulator but where does it hook up at in the dash? Any help would be great.
Tom 43
02-26-2008 14:44:53
 Re: 720 GAS in reply to EARL IN INDIANA, 02-26-2008 04:16:20
You have to go back to the A and B tractors to have two wires and a 4 terminal voltage regulator. The number series tractors such as yours have one wire and a 3 terminal regulator.
John T
02-26-2008 07:51:19
Earl, Either will work (with minor wiring changes) and the answer depends on if your set up for a 4 terminal (BAT FLD LOAD ARM) Voltage Regulator or a 3 Terminal (BAT ARM FLD) Voltage Regulator and some tractors got farmer Bob converted from 3 to 4 or 4 to 3 etc.
4 TERMINAL Those tractors had 2 wires from the dash to the genny/VR.
BAT on VR to load (NOT battery/starter) side of ammeter FLD on VR to gennys FLD post LOAD on VR up to dash to the BAT input terminal on the switch for its hot voltage ARM on VR to gennys ARM post
3 TERMINAL VR (only 1 wire to dash)
BAT on VR to ammeters load terminal ARM on VR to gennys ARM post FLD on VR to gennys FLD post The light switch got its hot voltage instead from the ammeters Load terminal, same one that wires down to BAT on the VR
John T Bloomington Indiana
Ben.So.Tex
02-26-2008 04:30:47
My 3 720's Lp's & 730 lp only have one wire from the reg to the amp guage and then to the switch and then on back to the battery/starter. The other 2 wires are from the reg to the two post on the generator. I am doing this off the top of my head. Some one else may have better info for you. Check the archive you might fine some diagrams ther.
