36 A no oil pressure
Chuck40
02-25-2008 18:37:12
Have a 36 A here that probably got condensation in the oil pump and I'm afraid the pump shaft drive gear is broke.
Pump shaft will not turn and it's been sitting for a day in a warm garage. Looks like the shaft coupler is fine---it's the newer one.
Is it possible to replace that drive gear by pulling down the oil pump and shaft, and is that all it takes to get at that gear?
Thanks,
Chuck
donwisc
02-26-2008 19:14:04
 Re: 36 A no oil pressure in reply to Chuck40, 02-25-2008 18:37:12
Not sure if the shaft and gear are keyed or splined. You may get lucky if its only a key.
Maark
02-26-2008 14:54:03
I've seen the inside of the coupler round itself out.
almrm
02-26-2008 05:43:50
Used oil pump parts are fairly low cost. I purchased an entire oil pump assembly with coupler on ebay for $10.00 plus shipping for my late A. I had 2 to pick from at the same price. I have the part and it is in good condition. I just looked and there are no unstyled A pumps but there is an unstyled B pump currently at $10.00 (unstyled consistent with styled prices). I have seen drive and driven gear sets also for even less (none currently). If you have time, what you need will likely come up on ebay. If you are in a hurry, the salvage yards should also be reasonable. There are no oil pump parts for an A on this site currently.
Good Luck
Mark
wilamayb
02-25-2008 19:47:58
If you are saying that the pump shaft wont turn when the flywheel is turned that leads me to belive that you have stripped the drive gear on the camshaft.
To answer the question.. Yes, you can remove the oil pump from the bottom with ease.
Chuck40
02-26-2008 04:07:29
 Re: 36 A no oil pressure in reply to wilamayb, 02-25-2008 19:47:58
Well, the camshaft gear is ok. Can't really see in there to check the pump shaft drive gear as it is ahead of the camshaft.
Just hoping I can get that pump shaft drive gear down by pulling oil pump and reaching in and around rods to get it down.
jdjerry
02-26-2008 04:27:42
 Re: 36 A no oil pressure in reply to Chuck40, 02-26-2008 04:07:29
I had the oil pump gear break on a 48 A but it took a couple of teeth out of the cam gear also.
