JD 60 fuel strainer / shutoff
bassndeere
02-25-2008 17:24:26
Finally happened, gas in the crankcase. Replaced both diaphams in strainer / shutoff, changed oil and filter, put 5 gallons of fresh gas in tank, it all siphoned into crankcase. What else should I replace in strainer/shutoff.
Thanks
bassndeere
02-26-2008 18:17:51
 Re: JD 60 fuel strainer / shutoff in reply to bassndeere, 02-25-2008 17:24:26
Thanks for all the advice. I checked on part no# A4987R and mine is made of metal not rubber. I cleaned assembly with Berryman's B12 before replacing the diaphams and everything seemed clean. Please tell me more about the vertical valve and o-ring. Are you referring to A4977R and A4978R ? Thanks again, Don
Kemper
02-26-2008 05:15:27
Did you replace the small rubber washer on the primer, JD part A4978R,that washer seals off the gas to the carb when there is no oil pressure to hold it open.
loneranger27
02-25-2008 19:49:07
I may be missing something but if your getting gas into your crankcase it can only get there through the carb. Your needle valve is not seating properly. it could be a simple as bending the float to raise a bit higher or replacement of the needle vavle and seat.
Pete76NY
02-26-2008 07:24:36
 Re: JD 60 fuel strainer / shutoff in reply to loneranger27, 02-25-2008 19:49:07
Lone...not true, remember that 50, 60, and 70 gas tractors have their fuel flow governed by oil pressure; if the diaphragms are bad, or there is enough dirt and junk (believe me it gathers) in the vanes, gas will flow right back down the lines into the crankcase.
John T
02-26-2008 07:37:51
 Re: JD 60 fuel strainer / shutoff in reply to Pete76NY, 02-26-2008 07:24:36
Ill add one more "true but" For gas to enter the crankcase via the carb, the shut off assemblys (if so equipped) vertical shut off plungers o ring/washer isnt turning gas flow off to the carb PLUS the carbs float n needle valve n seat has a problem allowing gas to overfill the carb bowl IE TWO THINGS BOTH HAVE TO BE BAD SIMULATANEOUSLY. For gas to enter the crankcase cuz the rubber diaphrams are leaky that only takes them to leak n gas flows down into the lil oil pressure sensor line to the crankcase. If that line is removed it better be oil ONLY n NOT gas lol I always replace the verical shut off plungers o ring/washer in addition to replacing the rubber diaphrams
Yall take care
John T
