JD 60 Draw Bar
Nick V
02-25-2008 15:08:30
How much can the draw bar on a JD 60 take? A friend recently loaded a 18 ft car trailer with green wood from cutting trees and loaded the front of the car trailer first and before I got there the draw bar was bent way down, near the ground. As soon I move part of the load to the rear of the trailer and balanced the weight the draw bar came back straight as before.
Should I be concerned that the draw bar may have been weaken or may be danger of breaking later?
I was just shocked when I first saw it, I could not believe it would ever be straight again.
Ray
Kemper
02-26-2008 05:21:12
 Re: JD 60 Draw Bar in reply to Nick V, 02-25-2008 15:08:30
Kinda sounds like the drawbar was slid out to the last hole? I think there are 4 holes?
john deere greg
02-25-2008 21:16:46
we had a 2600 gallon minure tank nearly full on our 620 to move around to a different barn. the bar flexed quite a bit until had to back up to the barn and then the pressure bent the bar nearly to the ground while still loaded. had to take the bar off and straiten in press but you cant hardly tell that it was ever bent. so i dont think you need to worry about it
F-I-T
02-25-2008 18:00:27
In 1970, my dad moved a house trailer across town for my brother, using the 70D. No one had a clue as to how heavy by the tongue this thing woulbd be, so when Dad dropped the jack that was under the tongue kind of sudden, the drawbar bent down probably 40*. As we all stood there in awe, he calmly hooked a log chain to the rockshaft arms which still had the flimsy cultivator brackets in place, wrapped the chain around the drawbar once, then hooked it tight to the lift arms, and rotated the rockshaft up, and by golly, that drawbar came right back up into place, and today you could not tell it was rever bent, and it has had a lot of use after that date. Those drawbars are very malleable, as you can tell by the way they wear the pin hole. Just straighten it in a press and I bet it will be fine.
OCB
02-25-2008 17:25:38
I have not seem a drawbar bent like that so I suspect you had a excellent trailer tonque also. As for me after you had the trailer heavily loaded and balanced a bit better, I would rather be on a 5500 pound JD60 than using my 8000 pound dually. That 11 MPH MAX versus 15, 25, 35 or?? MPH.
Clay
RobMD
02-25-2008 15:31:39
It's probably gonna be weaker, but that's besides the point. Two cylinders are notoriously lightweight in the front, and when you have a large amount of weight on the rear end, there is a good possibility of jacknifing and a loss of control. You certainly don't want to load an 18 foot car trailer full of anything with a tractor that light.
