2755 Overheating problem
dieselpup
02-25-2008 08:50:04
We have a 2755 that seems to run very hot - almost to the red whenever it is being worked. What is the normal operating temperature? What is the best method to check it out. Can the sending unit and gage be checked as well? We"ve replaced the thermostat and had the radiator cleaned but nothing has changed. I"m finding more questions than answers and would like to find the problem instead of replacing parts. Thanks!
buickanddeere
02-27-2008 01:45:40
 Re: 2755 Overheating problem in reply to dieselpup, 02-25-2008 08:50:04
Checking the gauge/sender unit was the correct 1st choice. Many concerns over "hot running" engines should not have been an issue.
A diesel should be running at 180F minimum and 195F ideally.
edhOH
02-26-2008 07:09:58
Welcome to the forum!!!
dieselpup
02-26-2008 07:59:56
 Re: 2755 Overheating problem in reply to edhOH, 02-26-2008 07:09:58
Thank you, I appreciate the suggestions so far. This is one problem I want to get fixed before we start making hay. I'm sure there will be something else to work on by then.
R. John Johnson
02-26-2008 04:51:26
Ours had problems with overheating one summer. Would heat up within 15 minutes, and it didn't matter what it was doing. Turned out the fins on the PLASTIC impeller on the water pump had broken off. New water pump and problem solved.
John
TractormanNC
02-25-2008 17:31:04
Had a similar problem on an open station 2750. Had aftermarket temp gauge on it, ran hot pulling a 7 ft sickle mower. Can you believe it? New radiator fixed that problem. Put a new temp sending unit in and hooked up to factory gauge, still ran about one needles width below the red. Took sending unit out, hooked up wire, put sending unit in water and heated water while monitoring temp with a thermometer. Guess what, 180 deg is about one needles width below the red! (put in a 170 thermostat, made me feel better)
woodvue
02-25-2008 09:56:38
My 2755 runs hot aswell in the summer when its really working. One thing that we did was lock the fan clutch on it. I think there is a lock up kit from Deere. I did the same thing when the fan clutch went out on my 4250
Steven
