49 snowthrower won't throw snow
Terry Lemons
02-24-2008 18:58:21
Hi
I bought a used 49 snowthrower on eBay, hooked it up to my 318 tractor, and found that the snwothrower doesn't throw the snow. The auger turns, but maybe it isn't turning fast enough?
I've been staring at the parts catalog for the 49. Assuming the belt to the tractor is tight, the only things that could cause the auger to spin more slowly than it should seem to be the chain drive on the side and the gear box.
Thoughts?
Thanks
tl
BillinCentralMO
02-25-2008 16:46:52
 Re: 49 snowthrower won't throw snow in reply to Terry Lemons, 02-24-2008 18:58:21
I wonder if it is geared for 1000 rpm pto and you are running at 540 ? Just a thought . I have seen stranger things. Good Luck.
jd51mt
02-25-2008 05:57:34
Terry,
Do you have the belt tensioner pulley engaged? It goes on outside of the belt and then you pull it towards the left side to engage it.
MIke
leon
02-25-2008 03:28:55
The previous owner didn't change some pulley or sprocket on it thus slowing the thing down for some reason did they? Is the engine speed on your tractor set up to spec? If it's a single stage snowthrower, without a blower separate from the auger, sometimes these machines don't work very well in really heavy wet snow. However, most of the time they do pretty well. That auger pin check is right on too - or a check for a sheared or missing pin or key for a pulley or sprocket. That too could let things turn with no load, but stop or slow way down under load.
j meyer
02-24-2008 19:33:18
This may seem silly, but did a shear bolt break? the auger may turn when you look at it, but under load its stopped.
Just a thought...
