'45 - A crank measurements
precisionag
02-23-2008 17:45:56
I am going to need some new rod inserts for my A . I am trying to figure out what the standard measurement is on the rod journal. Mine measures 2.971 . Thanks in advance for the help.
Bob
02-23-2008 18:46:00
 Re: '45 - A crank measurements in reply to precisionag, 02-23-2008 17:45:56
Did you measure it in at least 2 places, even more is better, to be SURE it isn't "egg-shaped"?
Duane Larson
02-23-2008 18:03:33
precisionag,
The connecting rod bearing is 3.002 and the journal is 3.000-2 (FSB 167 March 1950). So, the min is 2.998, so your crank is 0.027 under the minimum.
precisionag
02-23-2008 19:34:05
 Re: '45 - A crank measurements in reply to Duane Larson, 02-23-2008 18:03:33
Thanks for the help. I will measure some more to make sure that the measuremants are consistent.
