worn crankshaft splines
Larry5
02-23-2008 11:16:26
My 1947 "B" has wornout crankshaft splines for the pulley.
Besides a different crankshaft, can an adapter or shims be used to get the pulley tight Any suggestions will be appreciated.
Kemper
02-23-2008 17:52:03
 Re: worn crankshaft splines in reply to Larry5, 02-23-2008 11:16:26
The first thing i would do is buy a new driver and try that,you will need one anyway,i have an A that the driver was flush with the end of the crank,bought a new one and corrected the problem,has been ok for several years now.The crank is harder than the driver.
Larry5
02-23-2008 17:29:05
To Long Hauler
Thanks for your e-mail.
You state that the "link below " is for the supplier of undersized clutch drivers.
No link shows up. Would you send it again? Thanks---Larry5
WeirdDeere
02-23-2008 14:33:12
There is a company that sells "undersized" clutch drivers for this problem. I don't know if there is one for the B. And I've heard mixed comments on whether they are a workable option....
But that is something you can watch for.
Brandon
Kurt_JDB
02-23-2008 13:59:50
A machine shop that knows what it is doing can build up and cut new splines. The splines in your clutch driver are also probably damaged so you may want to check that out too.
There is a machinist by the name of Mike Williams that specializes in two cylinder crankshaft repair. I probably have his address around here somewhere, if you want it.
Kurt
Big Country - IL
02-23-2008 17:37:47
 Re: worn crankshaft splines in reply to Kurt_JDB, 02-23-2008 13:59:50
Larry - see the link below for Mike Williams contact info. He can rebuild the splines to new condition and is well worth the cost (my last B crank was redone by him).
http://www.greencollectors.com/cdps/cditem.cfm?NID=358
Mike Shuler
02-24-2008 09:15:26
 Re: worn crankshaft splines in reply to Big Country - IL, 02-23-2008 17:37:47
Guys, I am new to this site, but I have seen Mike William's work first hand on a crankshaft he did for my uncle's 38G. It is top notch. Depending on how much you want to spend and the detail you want to put into the quality of a restoration job, Mike's crankshaft work along with a NOS clutch drive disc would be a good option. Mike's rates are pretty reasonable too. His phone # is 563-243-4928. Hope this helps.
scott carter
02-23-2008 13:11:41
Get a taperlock flywheel. I've had to use them on several tractors. They are expensive but you won't have anymore problems ever. I tried the shim route it's fruitless,
thanks
scott
long hauler
02-23-2008 14:46:47
 Re: worn crankshaft splines in reply to scott carter, 02-23-2008 13:11:41
the link below is for the undersized clutch drivers. i had a weld shop fix my jd g and had to take it right back the first pull. you will be better off getting one unless you want to take the crank out send off pay to have it reworked and you still have to buy one.good luck.
long hauler
02-24-2008 12:19:07
 Re: worn crankshaft splines in reply to long hauler, 02-23-2008 14:46:47
Link this is the link for underdrive clutch drivers andn new and used parts.i went through the deal of welding up the crank in the tractor and buying a used one. TOO MUCH HEAD ACK. file you crank spines straight measure the thousanths under and get a new underdrive driver andn be done with it.
Mike M
02-24-2008 16:57:18
 Re: worn crankshaft splines in reply to long hauler, 02-24-2008 12:19:07
Be very weary of his so called undersized drivers ! I tried 2 of his for model A tractors over a period of years and neither one could you find any measurement on it that was different than a standard sized one. This was a big disappointment because I feel that a truly undersized driver would be a godsend to tighten these up without MAJOR work.
Mike Shuler
02-25-2008 12:07:43
 Re: worn crankshaft splines in reply to Mike M, 02-24-2008 16:57:18
Also, I wanted to mention that the drive discs that Dengler makes are harder than the crank splines. They make them from harder steel than Deere used to make thiers. If it runs loose, the disc will beat on the crank splines and wear the crank. A New Old Stock disc from Deere is a way better option than one from Dengler. Dengler"s are also rough on the inside where the splines meet. I have also tried shims but I don"t recommend it because they don"t stay tight. Mike.
