46 jd B puller
rotondo
02-23-2008 09:18:40
Anyone ever try boreing out a B under 200,000 for antique tractor pulling ? I am thinking of going to .125 high comp, w/ a puller grind cam, hot mag, polished head, cold gas manifold + a jetted carb. Also going to make it as light as possible. Flat back, hand start, dished rims. this is only going to be for antique stock tractor pulling in the new england area.
Hoss in ME
02-25-2008 18:03:07
 Re: 46 jd B puller in reply to rotondo, 02-23-2008 09:18:40
You guys all do the same thing;just wont admit it. Hoss,{with the "stock"47A}
jd b puller
02-24-2008 14:11:44
[quote="Joel B."](reply to post at 16:48:49 02/24/08) [/Just curious, how can you compete (legally) in a stock class with all those modifications?quote]
Look in the rules for MOST stock classes. Normally doesn't say -
- Must have stock Compression
- Must have stock displacement
- must have stock cam lift/duration
- must run 63 octane fuel as was available in 1942
It usually says - "stock appearing". Like it or don't, doesn't look like he's breaking any rules...
Joel B.
02-24-2008 12:48:49
Jon Hurley
02-24-2008 08:41:07
no wonder when some of us pull a truly "stock" tractor we don't have a chance
long hauler
02-23-2008 14:51:08
YOU SAID REMOVING THE STARTER? ARE YOU GOING TO PULL IT OFF EVERY TIME YOU WANTTO START IT.
ram ranch
02-23-2008 15:24:50
 Re: 46 jd B puller in reply to long hauler, 02-23-2008 14:51:08
He said Hand start, I don't think he said removing the starter? just ment coverting it to hand start flywheel. or maybe hes going to hang a chain off the front for a starter?(pull start).
jd b puller
02-23-2008 11:03:49
 Re: 46 jd B puller in reply to Grabatire, 02-23-2008 09:18:40
You didn't mention stroking it. If you aren't doing that, don't waste your money on the cam. Deere knew what they were doing, even 60 years ago. sent you an e-mail.
