39 B with dry tappet line from governor
brians in sd
02-22-2008 16:56:22
The governor on my just restored 39 B, is not sending enough oil to the tappet line. After complete disassembly and inspection, if you blow air through the hex connector that threads into the governor casting, air will only come out of the fitting in back that goes to the oil gauge. When you put your finger over the fitting, there is no air any where. Is it possible that I have one of those governors cases that John Deere did not drill out entirely? My governor case is #B1464R. How do I know for sure I may have that, and what would you do to tap it out to wherever it is supposed to go?
Mike M
02-22-2008 18:45:02
 Re: 39 B with dry tappet line from governor in reply to brians in sd, 02-22-2008 16:56:22
I'm not sure what is going on and where your air is or is not going ? but I was under the impression from the best I can recall ? that the tappets on those early tractors that run the tube on the outside up to the valve cover just get the splash off the gov. drive gears and catch it in a trough and then dribble it up through that line to the valve cover.
brians in sd
02-22-2008 20:27:37
 Re: 39 B with dry tappet line from governor in reply to Mike M, 02-22-2008 18:45:02
Mike M: You are right about the gears on my tractor slinging the oil up onto the catch tray, and then dripping down the tube to the tappets. After I posted this message though, I did find that there was a little hole (about a tenth of an inch) that was plugged enough that I had to take a tip cleaner to get it cleared. The hole that was plugged is right behind the thread where you screw in the fitting for the oil line that goes to the gauge. That little hole should help jet it from the bevel gears, and onto the catch tray. I'm hoping that it's going to be enough to make a difference. Tomorrow will be my trial run at that, when I get it put together again. Thank you for your input.
Mike M
02-23-2008 16:02:27
 Re: 39 B with dry tappet line from governor in reply to brians in sd, 02-22-2008 20:27:37
I remember that little hole on model A gov. too. And they were usually plugged up too.
