'35 A rear steel size
fixerupper
02-22-2008 15:48:05
Just received my document from the 2CY club on my '35 A. For special equipment it came with "aa8, 50 - inch skeleton rear wheels in place of regular rear wheel for Model 'A'".
So my question is, what size is the 'regular wheel'. The wheels were cut down and put on rubber many years ago. It has flat spokes.
Also, what's the significance of flat spokes VS round? Thanks, Jim
raddlechain
02-22-2008 17:10:00
 Re: '35 A rear steel size in reply to fixerupper, 02-22-2008 15:48:05
The "regular" wheel for a 1935 "A" would have been what is called "flat" steel wheels, with a rim 6 inches wide, and a diameter of 50 inches. Pressed-steel spade lugs were bolted to the rim. "Skeleton" rear wheels had a rim 1-15/16 inches wide, with cast spade lugs that bolted to the rim. These wheels were also 50 inches in diameter. Both styles of wheels used flat spokes.
Despite what some think, there were not "factory flat spoke" wheels for rubber tires in 1935. Round-spoke front and rear wheels were used for rubber tires. Steel front wheels also had round spokes, and many of these wheels were later "cut down" and the spokes were welded to a rim for rubber tires.
fixerupper
02-22-2008 19:45:19
 Re: '35 A rear steel size in reply to raddlechain, 02-22-2008 17:10:00
Well that pretty much answers my questions. Thanks.
Just for curiosity sake I wish I could talk to the origional owner or dealer to find out why they made the choice to go with the skeletons. Of course that's not possible now. Jim
raddlechain
02-22-2008 20:38:04
 Re: '35 A rear steel size in reply to fixerupper, 02-22-2008 19:45:19
Where are you located? The choice of skeleton over flat steel wheels was usually dictated by the type of soil the tractor was going to be used in. Heavy and sticky soils favored skeletons, whereas lighter soils tended to prefer flat steel. There were other reasons in some cases, but I know in the river bottom soils where I grew up, you just didn't see row-crop tractors with flat steel. Those tractors for which skeletons weren't available, such as "GP" and "D" tractors, used flat steel and scrapers, but if it was really wet, you just had to wait until it dried up, or they would ball up to where they'd rip off the fenders.
fixerupper
02-23-2008 06:34:38
 Re: '35 A rear steel size in reply to raddlechain, 02-22-2008 20:38:04
This is getting more interesting. This tractor went to Omaha and then to the dealer in Odebolt, Ia. The buyer lived in an area that does have heavier soils where compaction can be a problem.Jim
raddlechain
02-23-2008 12:21:45
 Re: '35 A rear steel size in reply to fixerupper, 02-23-2008 06:34:38
Yep, if he had valley or creek-bottom ground, then skeletons would have been the wheels to have in those soils, familiar with western Iowa.
Duane Larson
02-22-2008 21:07:34
The soils in the Deere-Webber Branch House out of Minneapolis, MN were such that they would not sell the A and B on skeleton wheels in 1935 and 1936. Quoting a D&W Bulletin dated May 1, 1936 "In making up the 1935 and 1936 Contract, the model 'A' and 'B' tractors were not listed with skeleton wheels. We have had this skeleton wheel since the advent of the old General Purpose tractor. In some of the Deere&Co territories most of the 'A' and 'B' tractors are regularly equipped with this wheel. This wheel has its advantages and disadvantages. In territories where the packing of soil is detrimental, and where the soil is of such a nature that the regular steel wheel with spade lugs fill up and cannot be kept clean, then the skeleton wheel should be used. The chief disadvantage of skeleton wheels is that it takes more power (in loose soil conditions) to operate the tractor, thereby increasing the fuel consumption and consequently increasing the cost of doing the work."
The Farmall F-12 was the chief competitor of the B, and it was not offered on skeleton wheels. So, a couple of neighbors in a comparison of power and fuel economy, one with an F-12 and one with a B on skeletons, the B would come out looking bad because of the wheels.
