Coolant drain plug
Gary Puckett
02-22-2008 15:22:54
The coolant drain plug has stripped in my 52 A. I think it is a pipe thread. It is the opening, not the plug. It has not completely stripped, but it will not seal enough to stop the dripping. I have put a lot of pressure on it and used sealing tape. Is there a solution short of tapping it to a larger size?
brians in sd
02-23-2008 09:07:45
 Re: Coolant drain plug in reply to Gary Puckett, 02-22-2008 15:22:54
I had a similar situation on my 39 B coolant plug. My threads into the head as well as the threads on the plug were bad. I had to grind and cut off threads on the plug, so that all that was left was the hex. I then had to weld on a new threaded bushing. After trying teflon tape, teflon sealer, pipe joint compound, here is what finally worked: Locktite #515. And then to make it more difficult, I couldn't turn the plug real tight for fear of stripping the threads in the head. But since it has a gap filling rating of .050 of an inch, it did the trick. Good luck with that. I see you have had some good advice on your replies. Something should work hopefully short of JB Weld. But if it comes to that, so be it. Good luck to you.
RODGEinIL
02-23-2008 06:34:45
I just used the pipe tap. I was lucky though..The taper on the tap was enough to make the threads catch and with some teflon tape-good to go! This was on a 1936 D.
Mike M
02-22-2008 19:06:11
Several options and alot of them have been mentioned. I have done most all of the following depending on the situations. Sometimes you don't get them on the first try then you try something else. -- Get a NEW plug from JD and use plenty of thread tape or hardening permetex. I even did my one B this way when full of coolant ! I rigged up a vacume cleaner to the radiator neck sealed up the overflow and turned it on. This held vacume in there while I backed the plug out and resealed it.
-- Oversize the hole but they are now 3/4" NPT and the next size is 1" NPT and that is a BIG jump in size and hard to do on some especially if on the tractor.
-- I found a tap that will just start in a worn out 3/4" NPT I think ? it is 1 1/16" X ? tpi I'd have to check. I was hopeing a commerical made o-ring bore type fitting plug would be available for that size as it was the next size up from the ones I new I could get. But I haven't found them yet. But that tap size works really good so I ended up makeing my own plugs. A custom made 3/4" NPT a little over might get most of them fixed but I have had some very bad up here in my area.
-- Epoxy a reducer bushing in there and then use a new smaller plug.
-- I think they do make a heli coil set up for that size but they are pretty pricey and I never bought one.
bill in western ny
02-23-2008 03:20:36
 Re: Coolant drain plug in reply to Mike M, 02-22-2008 19:06:11
how did you keep the vacuum cleaner from sucking all of the coolant out of the radiator?
Mike M
02-23-2008 16:07:24
 Re: Coolant drain plug in reply to bill in western ny, 02-23-2008 03:20:36
I don't know ? It didn't suck any up. I guess because the level was below the nozzle. I also didn't run it any longer than needed.
F-I-T
02-22-2008 17:08:04
Gary:
It is a tapered pipe thread. If you look at such a pipe tap, you'll see that because of the taper, you can create new full threads in a turn or so, sometimes more sometimes less, depending on the amount of erosion. I have such a tap at home and I have not had a head that I could re-thread this way. Now that's not to say that the new threads won't allow the plug to go in so much more deely that you might not have to modify the plug by grinding down the nose. Or, you can install a smaller plug into the correct bushing for the refreshed threads, then grind the shoulder off so the plug/bushing assembly (brazed together if you want) can go in all the way, and you have a good repair that will likely last another 60 years. I've fixed many this way, thought lately I've begun to turn a special plug with a thicker boss, so when threaded, it still sticks out enough to look "correct".
HTH
Frank
Wayne_H
02-22-2008 17:00:19
This might be a half a__ed solution... But you could put JB weld on the existing one, that will seal it up for sure. Then drill/tap another smaller hole. But, if the threads are tight and not totally stripped, did you try using teflon pipe sealer that comes in a tube? I've found it works a lot better than the teflon tape.
Wayne
johns48jdb
02-22-2008 16:39:14
on my 48b i couldn't get it out at all. so i drilled and tapped it for a smaller plug. you might want to consider doing this to yours before you put it back in and remember to hold that big nut and undo the little one if your ever have to drain it again. this doesn't solve your problem, but it will help from making matters worse. i'd consider a new plug to start with and then use some of the steel putty that you cut off of a stick in a tube, put it in and let it harden for 24 hours before putting water on it. i've sealed air tanks with bad threads on them doing it this way. good luck.
