60 radiator core gaskets
RONNIE FIVEASH
02-22-2008 10:45:39
just bought a new radiator core for my 60 from this site should i use permatex on the core gaskets
or just install them dry
RobMD
02-22-2008 12:45:03
 Re: 60 radiator core gaskets in reply to RONNIE FIVEASH, 02-22-2008 10:45:39
number 2 permatex. sticky, black schitt.
Mike M
02-22-2008 11:10:52
I make my own gaskets out of much thicker material than what JD sells. I have used gasket paper and cork rubber composition. If the castings are pitted I have put some sealer on them to help seal things up. I have also had several tanks resurfaced to clean them up too. The extra large sanding belt machine that the local engine shops use on alum. cyl. heads does a real good job on them.
