4430 Hydraulic Problem
Rick 580K
02-21-2008 18:44:34
I was reading post from yesterday about the hydraulic problem and the small hex shaft that drives the transmission pump. I have had to replace this shaft twice in the last year, what do I need to look for, need to fix before spring.
Heat Houser
02-22-2008 18:41:55
 Re: 4430 Hydraulic Problem in reply to Rick 580K, 02-21-2008 18:44:34
Is it rounded off in the middle or at the front end? If it is the front, here is a billet pressed into the crankshaft that drives the shaft. If the hex is worn, it can quickly round off a new shaft. The same goes for the one in the middle but in this case it would be the charge pump in the transmission that has the worn hex.
twopop
02-21-2008 20:04:11
As I remember the pressure should be 155 psi.my experience is to replace trans pump.used to be able to buy seperate parts,have to buy a whole new pump now
mattd
02-21-2008 19:12:48
check the system pressure. if too high the shaft can round off or blow the filter housing off. i cant remember the spec but should be less than 180 psi
