4240 3-point trouble
jd jim a
02-21-2008 18:41:52
Got a 4240 with hitch trouble. Problem number 1- the hitch will not start to raise until the lever is about an inch away from the rear end of the slot. Within that inch, it will go from full down to full up. Linkage seems to be moving through its full range. Problem 2, the hitch settles all of the way after the engine has been off for one minute. Any ideas?
Heat Houser
02-22-2008 18:36:49
 Re: 4240 3-point trouble in reply to jd jim a, 02-21-2008 18:41:52
Have the same trouble with my 4630. I have it apart and will get it back together tomorrow. One of the things that I noticed was one of the pins that pushes on the ball to lower the 3 point acted like the ball spring was broken. Jerked the cover off and the spring was OK along with the ball and seat. After I get it back together I am going to check if the pin acts the same before reinsataling the rockshaft valve back on the tractor. The ball may have gotten out of position in relation to the spring. I wont know until it is reasembled.
Heat Houser
02-23-2008 10:43:23
 Re: 4240 3-point trouble in reply to Heat Houser, 02-22-2008 18:36:49
Decided to reseal my remote outlets while I have it off. I did put the pins, balls and springs back in and now the pin is "spring loaded" I am quite sure the ball had gotten out of position. I'll update as soon as I get it back on the tractor.
Tx Jim
02-22-2008 04:15:02
 Re: 4240 3-point trouble in reply to DJD-Man, 02-21-2008 18:41:52
Jim be sure your L&D control is set in the "min position" not the "max posotion". Jim
twopop
02-21-2008 20:07:18
check the cross linkage under the cab.check pins where shaft fit the lever arm
mattd
02-21-2008 19:14:46
draft linkage needs adjusted. need a shop manual for this. try goin to your local deere dealer and see if the will photo copy the procedure for you
