Changing the oil pressure on a D?
greg
02-11-2000 15:27:59
How do you increase the oil pressure on a 1933 D? Is there an adjusting screw somewhere? Mine is only running around 5 lbs. pressure at present. Thanks, Greg
Bob
02-11-2000 20:27:39
 Re: changing the oil pressure on a D? in reply to greg, 02-11-2000 15:27:59
Gregg Email me and I will help you through this, turning up the pressure may not help much, as I think there is a real possabilty of another problem that is causing oil loss. Just been through this on a 38 D. Let me know if you have D parts book too as it will make it easier for me to explain. More than glad to help. Bob @
[email protected]
PS: If you happen by a JD dealer you might as well pick up gasket #A516R,
k hansen
02-11-2000 17:45:24
on a 36D the adjustment is under the main case cover. i suppose it is on a 33 also. remove the main case cover and you will find it.
