60 top water pipe
Ronnie Fiveash
02-21-2008 07:27:21
I HAVE A TOP WATER PIPE ON A 60 THAT NEEDS TO BE REPLACED THE PIPE IS 2-1/2'' THE MUFFLER SHOP HAS A 2-1/2'' EXAUST PIPE HAS ANY ONE USED EXAUST PIPE FOR THE WATER PIPE IF SO HOW DID IT WORK
630man
02-21-2008 08:23:10
 Re: 60 top water pipe in reply to Ronnie Fiveash, 02-21-2008 07:27:21
I used exaust pipe on my 60 and it works just fine
John
Mike M
02-21-2008 07:55:07
I have used exhaust pipe on several water pipes over the years. You have to really watch out on those sizes as John Deere liked to use ODD sizes like 2 7/8" instead of 3" so just make sure of the tube size. K & K antique tractors was carrying some of those odd size pipes. and even makeing water pipes.
I try to bevel the edges of the ends and use silicone sealer on the o-rings to help them slide in easy.
F-I-T
02-21-2008 07:39:22
Yes, I used the seamed-type �aluminized� steel muffler pipe for both upper and lower pipes on my 70 Diesel as well as a few others, and it has worked out fine. I removed the aluminum coating form the exterior of the pipe so that I had a steel surface to prime and paint later. I also buffed and polished the o-ring area so it would slip in to place easier. By far of any of the tasks I had performed over the years with respect to two cylinder repair, replacing those pipes and o-rings rank up there with the most difficult, right along with some Powr-Trol o-rings. My advice to you is to buy about twice too many o-rings in case you roll one and it gets cut, or one falls and rolls under the work bench. Then is not the time that you will likely want to drop everything and go crawling around looking for it. Over the years I have perfected my technique, so it is not too tough, but it can be a baptism.
HTH
Frank
