2040 starter problems
Richmarty
02-20-2008 21:45:21
We have a "79 2040, built in Germany. Sometimes when trying to start the engine with the key, the starter would stick. Turning the key back to off wouldn"t help, it would keep cranking. If the tractor starts (it usually does) everything is OK, it doesn"t keep cranking. Recently, on a cold start, the starter stuck on and cranked until I pulled the negative cables. When I hook them up the starter is still stuck on. Any clues?
buickanddeere
02-20-2008 23:40:23
 Re: 2040 starter problems in reply to Richmarty, 02-20-2008 21:45:21
Normal wear and tear from years of making and breaking 200 to 500 amps of current. The solenoid's internal contacts are worn and pitted. They are welding together like a stuck welding rod on steel. The starter motor will soon be ruined if the solenoid sticks. It's also possible to have a battery explosion if removing cables from the battery terminals while the solenoid is stuck. The solution is usually a new solenoid. However sometimes the contact disk inside can be rotated a 1/4 or 1/2 turn to expose a less damaged surface. This temporary fix will at least get the tractor running a few times. The original starter is a Bosch unit likely rated at 3KW or 4HP. There is an optional HD 4KW or 5-1/3HP Bosch starter used on that four cylinder 239 engine and on the six cylinder 329 and 414's etc. This would be the time to upgrade for surer starting on cool days. The original starter motor will be worn out by now with short brushes, rough commutator and worn bushings. The pinion and over running clutch will be also worn almost to the point of failure.
