Crank and rod bearings
Dave in SV
02-20-2008 20:06:10
What are babbeted crank and rod bearings?
Bert66
02-20-2008 20:46:45
 Re: Crank and rod bearings in reply to Dave in SV, 02-20-2008 20:06:10
It means the bearing was formed by pouring molten babbet in the block or rod. Newer engines use insert type bearings which are much easier to replace..
Dave in SV
02-21-2008 05:53:55
 Re: Crank and rod bearings in reply to Bert66, 02-20-2008 20:46:45
Thanks for the clarification. It appears (per the PC675 Parts Catalog) that my '49A has inserts.
ram ranch
02-21-2008 07:48:04
 Re: Crank and rod bearings in reply to Dave in SV, 02-21-2008 05:53:55
Just because it says it in the parts book, dosn't mean it's the same in your tractor? just better take the crankcase cover off and check to be safe.
Dave in SV
02-21-2008 08:45:30
 Re: Crank and rod bearings in reply to ram ranch, 02-21-2008 07:48:04
That is a very good point!
PBrowning
02-21-2008 09:08:13
 Re: Crank and rod bearings in reply to Dave in SV, 02-21-2008 08:45:30
Dave -- ram ranch's comment goes along with my email to you on the issue. Even with a late tractor, Babbitt is always an option, albeit not often used. So opening the crankcase before buying is always sound advice! (PatB)
