69' 4020 pump
RustyDeere
02-20-2008 16:44:26
My 69 model 4020 Diesel has the small roosa master
pump model # CBC633-28AL. The pump is weak and I need to replace it. I have found another roosa master pump off of a 67 model 4020, the model # is DBGVC633-3AJ. Will this pump work on my model?
Will I have to change the injector lines? The block
# on my tractor is M23RO 226628R. I appreciate any info.Thanks
msb
02-20-2008 19:50:12
 Re: 69' 4020 pump in reply to RustyDeere, 02-20-2008 16:44:26
The lines including the return line and supply lines, some parts of the linkage and some way to shut the engine off since the 69 and up had an electric shut off. An electric shut off from a pump with one can be adapted to the 67 model pump.
