40 B Fuel Line Filter
B_Bob
02-20-2008 13:06:56
Am in the process of putting everything back together on my 40 B after having the fuel tank dipped and spending $$$ on rebuilding the Carburetor. Would like to put an inline fuel filter just before the carb as a last stand to keep the Carb clean. I would appreciate any opinions/advise on the subject and what kind of filter I should use.
Thanks,
Bob.
old
02-20-2008 14:18:25
 Re: 40 B Fuel Line Filter in reply to B_Bob, 02-20-2008 13:06:56
Most in line filters cause more problem then they fix. If you think you have to have one go to a motor cycle shop and buy one made for a motor cycle. Ones made for cars/trucks are made for fuel systems with fuel pumps that put out 7PSI pressure plus up to around 75PSI and theres no way a gravity flow system will do that. Filters made for motor cycles are also made for gravity flow fuel systems so thats why they work but still not all that good either. Thats why the sediment bowl has a screen in it or should have a screen, if yours doesn't get one for it
