2350 draft link seals
VKG
02-20-2008 10:44:09
Have a john deere 2350 that the seals where the draft link hooks up to the shaft that runs thru the tranny is leaking bad.My book is alittle vague so I'm asking for some advice.Do I simply remove the shaft after I drain the tranny fluid, how do I remove the bushings? How do I reinstall the bushings, Seals, bushing spacers? I want to address all of these things while i'm in there just want to do the job right the first time. I have never done this type of repair before so any advice would be very mutch appreciated.Thank You in advance.
Mark
rls
02-26-2008 05:52:15
 Re: 2350 draft link seals in reply to VKG, 02-20-2008 10:44:09
have 2250 it was leaking to after removing pins on end of shaft and link arms from shaft i removed the shaft to check for wear groovs on shaft the shaft will have flat spot machined in the center witch rest inside trans against a spring loaded plat to keep the flat side there you just replace the seals on both sides slide shaft back in just like you took out dont forget shims between link arms and seals mine took 6 on each side
DSF
02-20-2008 17:54:33
There is a cap on the end of the load control shaft w/ a spring clip that holds a pin in the cap.
Drain the oil, remove one side at a time. Take the cap off, remove lower lift link, slide shaft out the opposite side just enough to repl. the seal on the side you are working on. Reattach everything and repeat the other side. I have replaced them on my 2755. It will take you longer to drain and repl. the oil than it will to put the seals in. Mine was leaking bad and this fixed it. Hope this helps. Have a blessed day.
