3020 Almost statrs but dies.
Montana3020
02-19-2008 18:54:15
I have a early 3020 powershift gasser that will not start. It has only run six hours since I bought it. I have tried a zenith and a marvel usx 36. I have tried to troublshoot this thing but I cannot find anything wrong. I got good fire from new plugs and good fuel pressure. I have cleaned the carbs and put basic kits in them. I did notice that the fuel is filling the carb to the point it spits it out. Any body with any ideas? I would be very greatfull for any help.
Gerald J.
02-20-2008 10:12:10
 Re: 3020 Almost starts but dies. in reply to Montana3020, 02-19-2008 18:54:15
Like my early gas 4020, the 3020 gas surely uses a 6 volt coil with a resistor for running that is shorted out by the R terminal on the starter solenoid for starting. So when the run line goes open, it will fire while cranking but not keep running when you release the starter button. Originally the run wire came from the ignition switch and there's either a resistor coil on the switch or they used a resistor wire. On mine the wiring had been reworked with a resistor block at the coil and the new run wire was ried in with a scotch tap and it was the scotch tap that was open.
In the meantime to finish haying, I hot wired the coil and resistor. That can be your test. Run a wire from the battery terminal on the starter solenoid to the hot wire (not the one to the distributor) on the coil.
The Zenith carburetor is the easiest one to make run good. Often needs a float needle and seat to control the fuel level. Should be spitting fuel out under any condition.
In cool weather the gas engine needs manifold heat. For the 4020 cool is below 70 unless plowing.
Timing is important. Condition of the condenser is too.
Gerald J.
Montana3020
02-20-2008 17:10:08
 Re: 3020 Almost starts but dies. in reply to Gerald J., 02-20-2008 10:12:10
Thanks for the help Gerald J. and Bob, I will try the test you suggested. I did make a conversion to a 12V flame thrower coil and electronic ignition. The tractor ran after the conversion. The ignition switch is old and some times will start slightly without the clutch in and the gen/alt light and oil light will blink or not come on at all. I jiggle the key and and it works. The switch has a resistor which is rusted. I want to replace the switch with a new one, know where I can get one?
Bob
02-19-2008 19:24:08
 Find a tractor buddy! in reply to Montana3020, 02-19-2008 18:54:15
Can you find someone with a little gas engine/tractor experience to take a look at it?
In the time it would take to type out some suggestions, someone with a little experience would have it fired up!
Montana3020
02-20-2008 05:21:43
 Re: Find a tractor buddy! in reply to Bob, 02-19-2008 19:24:08
Thanks Bob....I have been looking for somebody around here but I haven't found anybody yet. I will keep looking....Thanks.
Bob
02-20-2008 06:10:27
 Re: Find a tractor buddy! in reply to Montana3020, 02-20-2008 05:21:43
No luck with any local help, then. Shucks!
Check to see that it has a HOT spark... use a spark tester, or a spare spark plug with the gap opened up to 3/16".
If the spark jumps that, it is HOT enough!
If you have been dinking with it, and flooding it, try a NEW set up spark plugs. If the plugs have been wet with gas from the starting and flooding attempts, they will not fire under compression.
Check the timing.
I don't know if you have the tractor in a warm place, but being WARM sure helps a stubborn engine start.
If you can do it safely, with trusted help, try pull-starting it. This spins the engine faster, for better compression, and having the starter load off of the battery makes for a HOTTER spark.
If NONE of this helps, do a compression check, to rule out anything WEIRD that may have happened to the engine.
Bob
02-20-2008 06:33:10
 The pull-start suggestion ain't gonna work!! in reply to Bob, 02-20-2008 06:10:27
Sorry about that. When making the second post, I forgot it was a powershift!
Have you pulled the transmission disconnect lever at the LH side of the steering pedestal, to disconnect the PS tranny from the engine, for easier cranking?
Another thought, that tractor will have a "starting bypass" system in which the "R" terminal on the starter solenoid is wired over the the igntion coil, to bypass the ignition ballast resistor for a HOTTER spark during cranking. That wire takes a round-about path up and around over the back of the engine, over to the coil. LOTS that can go wrong there!
Montana3020
02-20-2008 17:05:09
 Re: The pull-start suggestion ain't gonna work!! in reply to Bob, 02-20-2008 06:33:10
