JD 4000 Alternator Upgrade
MGolden
02-19-2008 07:14:40
I have a model 4000 that has an external regulator on the alternator. It has gone bad, again, and i would like to convert this to the delco style that is on my 4430. Can anyone help with how to do this. There are a lot of wires on the current alternator and i am not sure what they do or how to connect them to the Delco style with the dual blade connector. Any help would be appreciated.
Bob
02-19-2008 19:29:48
 Re: JD 4000 Alternator Upgrade in reply to MGolden, 02-19-2008 07:14:40
1.) Get a Delco 10SI or 12SI alternator.
2.) Figure out which wire NOW going to the voltage regulator is from the dash-mounted "idiot light", and connect to to the new alternator's #1 terminal, and DO NOT worry about the diode shown here... you WILL NOT need it 'cause you are using the factory "idiot light".
Third Party Image
Mike Aylward
02-19-2008 15:07:35
MGolden, this is an easy swap. There is an adaptor harness that will go right into your tractor harness and connect to the Delco alternator. When I was a parts manager we always went to a 7520 tractor (the OLD one now) and it would be listed there. We always kept this harness for this application. Perhaps someone can give you the part number. If your dealer doesn't have it many starter shops will. Hope this helps. Mike
Gerald J.
02-19-2008 11:58:29
12 or 24 volt? Delcos are uncommon set up for 24 volts on the diesel. But 24 volt alternators were supplied on 4000 with cabs and airconditioning. And will have lots of wires because nothing at the alternator is grounded, there are two wires for field, and two for output...
Gerald J.
Kent Petersen
02-19-2008 16:59:38
 Re: JD 4000 Alternator Upgrade in reply to Gerald J., 02-19-2008 11:58:29
Gerald i don,t think deere ever put 24 volt on the 4000 tractors cab or not Kent
Gerald J.
02-19-2008 18:25:15
 Re: JD 4000 Alternator Upgrade in reply to Kent Petersen, 02-19-2008 16:59:38
Since my parts book and shop manual covers the pre side console 4020, before the 4000 was made, I can't tell. But weren't side console 4020 sometimes made 24 volts when diesel without cabs? Why would the 4000 have been different?
Gerald J.
Kent Petersen
02-20-2008 03:17:35
 Re: JD 4000 Alternator Upgrade in reply to Gerald J., 02-19-2008 18:25:15
Gerald all 3020 and 4020 side consoles were 12 volt 1969 and up KENT
M meyers
02-19-2008 09:42:03
Just use a delco that only uses the one bat. wire.
