DLTX 10 Carb.
James Tabor
02-19-2008 06:43:09
I just removed the carb. from my hand start 45 B. It is a DLTX 10. According to my shop manual this is the wrong carb. Sorry I can't remember the correct DLTX number as I am not around my manual. The tractor ran just fine with the 10. I had to remove it to work on the head. From what I can find the DLTX10 belongs on the unstyled tractors. Does my hand start tractor, eventhough considered an early styled model,possibly require this 10 since it is not electric start? I wouldn't think so but thought I would ask. Thanks.
PBrowning
02-19-2008 09:43:37
 Re: DLTX 10 Carb. in reply to James Tabor, 02-19-2008 06:43:09
James -- There is a neat piece over at the JD-H Restoration Site (below) on this subject. Scan across to ARTICLES 1, and from the drop-downs, select CARB ID CHART. It makes a very handy "quick reference" for carburetor ID and the Waterloo tractors they go with. (PatB)
Mike M
02-19-2008 07:25:57
I wouldn't get too worried about it. I have not found any troubles with running carbs. for any model B on a model B or any for a model A on model A's. But what I have found troublesome is when someone puts a model B carb. on an A or an A carb. on a B or even an H . Now that will goof you up !
John T
02-19-2008 06:50:39
James, Im NOT any carb expert but believe the upgrade when they went from unstyled (1938) to styled (1939) on the B was because they increased the displacement and the compression to gain more HP and required a higher CFM rated carburetor was required. The 10 can start n work but if push comes to shove and you wanna really work it hard the 10 may not deleiver quite enough CFM of the fuel/air mixture to get all the HP the engine (with nore cubes then the predecessor) is capable of providing.
Im sure Duane or Frank or people with carb or CFM specs can correct any of my errors
John T
Duane Larson
02-19-2008 07:45:18
 Re: DLTX 10 Carb. in reply to John T, 02-19-2008 06:50:39
John T is correct - the bore size on the throttle end increased from 1 5/16" on the DLTX10 to 1 3/8" on the DLTX34 it came with, while the choke side remained 1 5/8", and some internal passage sizes changed. For parading around it should work ok, but if you decide to participate in a plow day, you may be a bit short on designed horsepower with the DLTX10.
James Tabor
02-19-2008 10:49:34
 Re: DLTX 10 Carb. in reply to Duane Larson, 02-19-2008 07:45:18
Thanks for all of the info.
