HELP 35 A transmission shift handle
n29we
02-18-2008 16:54:49
Hello all - I've got a problem that cropped up yesterday in our local winter carnival tractor parade. 60 plus or minus tractors, quite the show. Anyway while preparing to shift from from second to first the shift handle suddenly fell into the transmission leaving about 4 inches of the handle showing. It was still in gear so I continued the parade holding the handle up. You can pull it up to the normal position but whatever secures it has failed. I tried to hold it up in the normal position to shift into rev but no go. Got it home in 1st gear. I have not opened the top of the trans yet but I'm wondering what I should be looking for when I do. Any help / advise?? Thanks - JimO
RobMD
02-18-2008 17:13:53
 Re: HELP 35 A transmission shift handle in reply to n29we, 02-18-2008 16:54:49
Your snap ring, which holds the shift ball mechanism thingie in place, has broke off from rust. It's an easy fix, you'll have to remove the cover so you can check and make sure you didn't lose anything in the tranny.
