MRN: Hopefully some of the real mechanics on here will answer your post soon. Anyway here is my recollection of the same problem I had on a 4010 a few years ago. If memory serves, everything worked ok after reassembly except the control arm was in the wrong position. I determined where the contol arm position should be by operating the arm by hand (raising and lowering the 3 point hitch) and comparing to the the cable end connection from the dash operating lever. I removed the rockshaft valve housing and adjusted the control arm accordingly (you can see how the valves work i.e. neutral, up, down, etc. with the housing upside down on a work bench. There are also timing "V" marks to align. There is a procedure listed in the shop manual for making an adjustment if the control arm is just outside the threaded adjusting limits on the control cable (without removing the valve housing). But, it didn't seem to work well for me.....remember, I'm not a mechanic! The manual says: Remove the filler cap and nipple. Before loosening the control quill (arm), insert a large screwdriver through the filler opening and use it to apply pressure against the pinion gear to hold it in mesh with the inner sector gears. Loosen the quill and carefully slip the outer sector gear one tooth at a time in the proper direvtion to obtain the necessary adjustment. Tighten the quill before removing screw driver pressure from the pinion gear. Again, I think this is for a small adjustment only, and probably not practical when the control are is way off. One other thing I remember regarding putting the entire rockshaft cover on (not the valve housing) was getting the roller of the load selector control link, in the valve housing, on the backside of the cam follower. Seems like we had a lot of problems getting this accomplished. It would be very easy to screw this up if you didn't watch it closely. I'm assuming you have a shop manual of some kind. If you don't, I could scan you some pages from my JD service Manual (for JD 4000 series tractors). If you need them, email me at [email protected] Hope I haven't confused you too much! gwece
