3020 diesel fuel pump
Larry M
02-17-2008 18:18:11
Does anybody have or know a web site or picture of a cut away veiw of a fuel pump used on a 3020? This one is leaking around the head. maybe o ring , but not sure what comes out when you un-screw the head of the pump. Any ideas? Thanks
Mike M
02-18-2008 09:45:34
 Re: 3020 diesel fuel pump in reply to Larry M, 02-17-2008 18:18:11
Are you sure it just isn't one of the lines leaking at the metal washers that seal them ? This is VERY common.
Do not check with your fingers as high pressure fuel spray can poison you !
jdemaris
02-18-2008 06:32:56
 A few photos in reply to Larry M, 02-17-2008 18:18:11
Here's some stuff on both model pumps.
third party image
third party image
third party image
third party image
third party image
third party image
third party image
jdemaris
02-18-2008 05:53:41
It depends on what pump you have. Your tractor came with two different model pumps - a C series and a D series. The C series is round and has a power wire the is a push-on fit to the little round solenoid (if elec shutoff). The D series is rectangular and has a three-bolt cover - and - if it has a solenoid it is built into the cover. Both have to removed to reseal a head-leak - assuming you know what the head is. No insult here - but you might be using a generic term, whereas - in injection pump terms - the "head" is part of the head & rotor assembly. On the C pump, the aluminum part in front of the pump is separated from the head assembly and a new o-ring easily installed. On the D pump, it is much more complicated. The pumps has to come all apart, and the head fits tightly inside the aluminun housing and fits inside a large o-ring. Complete seal kits cost around $12.
I'll post pictures after you tells us what pump you have.
Bob
02-17-2008 19:11:55
What comes out is pretty much EVERYTHING, including the governor. It also gives you the opportunity to get the rotor and driveshaft 180� out of time.
But, first you have to free the advance piston from the cam ring, and remove the fuel metering valve down below the pump cover.
ANd, yes, the head is sealed to the aluminum case with a thin cross-section "O" ring.
jdemaris has some photos scanned he posts from time to time. HOPEFULLY, he will see your post, and reply.
Larry M
02-18-2008 01:59:28
 Re: 3020 diesel fuel pump in reply to Bob, 02-17-2008 19:11:55
Thanks Bob. The problem is it is just leaking around this head. I didn't want to take it out and everything in there come flying out at me.
