Cylinder crosshatch
Dave in SV
02-17-2008 17:19:43
... been reading up on cylinder boring, etc. There's talk about "retaining enough depth in the crosshatch for good oil retention and lubrication." Crosshatch doesn't remain on the cylinder walls permanently, does it?!?!? "Retaining enough depth in the crosshatch for good oil retention and lubrication" must refer to the break-in period...?
jdemaris
02-18-2008 06:40:43
 Re: Cylinder crosshatch in reply to Dave in SV, 02-17-2008 17:19:43
I've seen tractors with 10,000 engine hours and cross-hatch marks still present - same goes with cars with over 500K. All depends on how used and how well taken care of. I've also pulled apart tractors with less then 500 hours that were all scuffed, scored, and most markes goen. I once bought a 65 Pontiac GTO - literally from a little old lady who only used it to tow a boat on the highway. 389 with tri-power. I bought it with 105,000 orig. and well cared-for miles - which is highly unusual for a 60s muscle-car. It ran fine, but I pulled it all apart anyway to put a hotter cam, valve parts, headers, etc. The cylinders looked like new. I recently blew the engine in my Chevy 87 6.2 diesel Suburban with 520,000 miles - and the heads had never been off. The crank and block broke and I stripped it down. The cylinders still have cross-hatch marks. I put a head-gasket on my wife's 91 Volkswagen Jetta diesel at 180,000 miles - cylinders looked like new with full cross-hatch patterns.
johns48jdb
02-18-2008 04:57:34
i learned recently that you should run your drill, thats driving the glaze break tool, in both directions and not just one. this creats a true cross hatch pattern.
Sam#3
02-17-2008 18:51:09
I had a '83 mazda pickup a few years ago that had a propensity to blow head gaskets. The last time I had the head off it 252k miles and still had the crosshatch and very little wear ridge. With good oil and service they last a long time.
rexhellwig
02-17-2008 18:20:52
Try to find a factory IH 400 series engine manual. Read up on a procedure they called "plateau honing". Pretty interesting. It's kind of a two step, coarse-fine liner finish.
LarrySTN
02-17-2008 17:52:55
Cross hatch remains in the bore long after the breakin period. We currently have a John Deere 7810 in our shop. At 4500 hours the cross is still in the bores, from the bottom to the top of the sleeves. The reason for the engine apart...a piston has a broken ring land. Bores look like brand new with no ridge.
F-I-T
02-17-2008 18:13:49
 Re: Cylinder crosshatch in reply to LarrySTN, 02-17-2008 17:52:55
When I tore down my 70D we estimated it had in excess of 7,000 hours, and there was still a majority of the cross-hatch pattern. Old age, and sitting outside for 15 years allowed water to get in and pit the cylinders. Otherwise, I'm not too sure a really good honing might not have allowed a standard set of rings to work. Still, the fresh cylinders, pistons, rings, and a few hours on the dyno sure made for a quick break-in.
Frank
Bob
02-17-2008 17:24:48
Yes, for the break-in period, and the crosshatch DOES last a LONG time below the ring travel area of the bore.
RobMD
02-17-2008 20:45:24
 Re: Cylinder crosshatch in reply to Bob, 02-17-2008 17:24:48
Yeah, absolutely. However, if an individual continually runs any engine low to very low on oil, then those walls get nice and vertically micro-scored over time..
RobMD
02-17-2008 20:48:42
 Re: Cylinder crosshatch in reply to RobMD, 02-17-2008 20:45:24
BTW, FWIW- At least just in MY experience with vertical one cylinder engines and 242 mopars. Most two cylinder tractors i've had still had some sort of cross hatch, but the farmalls were all worn smooth.
